- 16 Jun 2010
- Manchester
Right guys i have it running at 4Ghz @ 200bck with 1.26v CPU, 1.35v Qpi, 1.65v Ram.
Memory is running 1600mhz with 9.9.9.24 and everything else on auto.
Now i have been running Prime 95 Torture test for hours on small fft's with no errors, even if i switch to blend it will go for hours even while im browsing in the background.
Temps never go above 77c with my VX.
Thing is when i run OCCT it fails within the 1st 2mins... now when i run the memory part on OCCT it will pass no problems on 20 passes, and OCCT linx just keeps plodding on...
What should i do or what would you suggest ?
