So the 990x will use less voltages to overclock and has a revised memory controller though what does this mean in the real world? I'm trying to work out the following:
1. If both processers are OC'd to the save levels, will they perform exactly the same?
2. If the 990x uses slighly less volts from what i can gather to achieve the same OC levels, how much less heat would i expect over the 970?
There's a bit of a price difference between the two and i understand, bang for buck, the 970 is the obvious choice. Though just wanted to know before purchasing if anyone could give a reason to spend the extra on the 990x?
Silver
Silver
