i7-9700k / ASUS ROG Maximus Hero XI - help pls
30 May 2016
Anyone able to give me some BIOS settings to OC the mutha up, STABLE, like?
It SHOULD do 5.+ ghz. I bought it as part of 5.1ghz bundle - then promptly nuked the OC profile that was set up for me...doh!
I think it might worth to try asking in the "Component Technical Support section" under "OcUK Customer Service" section of the forum, quote your order number and explain your situation...they might get back to you with the information/profile they used for that bundle.
Sadly, no. Different CPUs have different settings, which make sense. The OC Profile for one i7-9700K won't work on another. Seems like an RMA is the only way to do it - ar*e.
