- 5 Jan 2019
Hello everyone. I've just bulit a new pc, been waiting for it for a long time and I came up with some issues with it.
PC: I7 9700k
Noctua NH-U14S
Case : Silentium PC Armis Ar7 with 2 additional fans
Gigabite Aorus z370 k3 gaming
16 GB of Corsair Vengence 3000 Mhz Ram
Gtx 1070 from EVGA
PC: I7 9700k
Noctua NH-U14S
Gtx 1070 from EVGA
- First thing I noticed is that temps were high in idle. In high 30 low 40s. But it was idle I didn't mind. But when I started playing I noticed after some time that my frame rate dropped from having 300 fps in csgo down to like 150. I thought to myself that can't be right so I checked and the temps were in the high 80s some cores were at 90°C. That's not good. Turned all the fans to max rmp so it's better but still very high.
- I noticed that my voltages are high while I was trying to figure our what's the issue. I'm getting roughly 1.45V. What the hell ? I checked online and I should be getting around 1.25-1.3 So that's probably the issue of my heat. Tried to lower Load line calibration In bios but I wouldn't let me so I found it in a motherboard software app that let me change it from high to medium or sth like that It wasn't really precise.
- So my question is: is it motherboards fault for giving too high voltage? Is it my bad cooler and should I just go liquid ? Or am I just unlucky on the silicon lottery and I have a ****** cpu? Ps; I'm pretty sure that the 9th gen i7 should hit 4.9 ghz at least on 1 core right? The highest I've seen mine go was 4.7 which I think is due to the temperature throttle. I need help plz save me ;*
