Is it worth buying the i9-9900k over the i7-9700k?
What are the pro's and con's?
For example I don't want to buy the i9 if it's having teething problems are is simply no better than the i7.
Mainly heavy duty gaming.![]()
Not much in it...might aswell go 9900k unless you can wait for Ryzen 3700x
I had a 9900k ran it 5ghz all cores...make sure you get a decent AIO
It’s a great chip but expensive...
100%, for the £40 difference is price the extra 8 threads are worth having
Even if you prefer Intel (and Nvidia) it would make sense to wait for Ryzen 3000 if you can as it will (likely) drive down the price of the 9900k.Okay thanks. I was just a bit worried there might be some problems with the i9 with it being relatively new, and also the extra heat thing . I swapped over from AMD years back. I don't really want to go back to it. I found the intel - Nvidia formula worked much better.
£40 and is sort of future proof. I was leaning towards the i9 anyway but thought I would make sure I wasn't missing something.
It really isn't enough for future proofing, when 12 cores/24 threads can well be fair £300 level in June.£40 and is sort of future proof. I was leaning towards the i9 anyway but thought I would make sure I wasn't missing something.
Model line up is likely announced in start of Computex.So there could be a price reduction when the new Ryzen is on sale. When roughly will that be?
i7 isnt vulnerable to portsmash, which is a plus along with the price.
Although as said Zen 2 should be worth waiting for.
Seems we have for's on both CPU's. As I said I was enquiring to se if there was any problems with the i9, but there doesn't seem to be any except for it running hotter than most.
My intention was to build a top end computer, thus the i9. There again the i7 should be more than sufficient. I'm going to sleep on it.
What's 'portsmash'?
These CPU vulnerabilities are generally only reproducing under very controlled conditions and scenarios. Yes they're there, but they're next to impossible to exploit on a regular chaotic system. I really wouldn't get too hung up about it.
