Mainly for school work and playing the odd game. I know it's a lot more powerful than needed for that but I want something thats going to last me and will be quite powerful, also upgrade proof!
Its pritty awesome.
But the cost is about exactly the same as the goliath.
So I would buy that instead, and get the OCing they do for it for the extra buck and pre built.
Well it's still a few months away before I start post 16 education and my sixth form is being built adjacent to my current school and it's not completed yet so I don't think things like that will have been sorted. Thanks anyway
For this software to install correctly customers must have ONE of the following:
1. a previous Windows OS (XP/Vista) currently installed on the computer or laptop, or
2. the serial key from a previous Windows OS (XP/Vista) which must be entered in order for the upgrade DVD to install the full version of Windows 7 onto a blank harddrive.
Either way, you MUST own a license to a previous version of Windows XP / Vista.
Does this mean I can use the product key from the bottom of my Laptop on my new harddrive?
