- 8 Oct 2009
I will probably order tomorrow or the day after so please can you answer some questions...
1) Will the 5870 graphics card fit into my Antec 1200?
2) Should I get the Asus Rampage II Extreme instead of the Gigabyte GA-EX58 UD5?
3) I need a CPU cooler. Can you recommend one for my Antec 1200?
4) I love the Antec 1200. However some people think that it is not big enough. What do you think on this matter considering my specs and gfx? If there are better cases can you recommend one?
Any other suggestions?
Thanks
you could always use a True as the cooler and add some fans of your choice. Also, if i was you, i would just got for i7 just because of the extra threads for not much different in cash. Also, you may need a decent sound card? the asus exstream 2 has xi fi sound card
