Hi,
I've finally decided to build myself a new pc. I've never built one before but am pretty confident I can do it. Only problem is I need LOTS of help with the spec.
Case > Silverstone FT02B
Q1. I'm absolutely smitten with the silverstone Fortress 2 ...AP181s are £14.66 each. That’s £43.98 added to cost of case for this minor upgrade. The new Red edition is only £23.50 more with these as standard.. Is this a worthwhile upgrade? Does anyone know when the revised edition will come out?
Also should I expect to replace the top fan with something quieter? (if so what?)
PSU > Corsair HX850X
Q2. This seems like the best Modular Power supply for if/when I decide to go SLI or Crossfire at a later date. Is this ok?
Motherboard > ASUS P6X58D-E
Q3. Can't decide on the P6X58D-E or the GA-X58A-UD3R??? (silly thought) If I were to go for the red case with a window I should probably think about a less blue Motherboard?? Perhaps? Not too fussed about having window in the first place.
CPU > I7 950
Q4. I will be using mostly Photoshop and zbrush as well as Maya and of course games. This has now dropped enough in price for me to consider. Is this a good idea?
RAM > Corsair 6GB XMS3
Q5. I may go for 12GB at a later date (another 3x2GB of same) is this my best choice? I'll need low profile if I'm to get the CPU cooler I want
GPU > ????
Q6. Nvidia or ATI? Am I right that Nvidia are better for Photoshop, Maya etc? Will a GTX460 Suffice for now? Or should I take the plunge and go for a 480? Or is there evidence that the ATI 5870 is just as good for Photoshop and Maya? Also do I really need to concern myself with air cooling heatpipe cards having problems in a FT02 case?
CPU Cooler > Noctua NH-D14
Q7. I have read hundreds of reviews and can't decide on the NH-D14, Polimatech Megahalems or the Thermalright Silver Arrow? Quietest coolest solution?
SSD > None at this time
Q8. I WILL be getting one of these just not sure I'll need it straight away. The 128GB Crucial C300 seems ok?
HARD DRIVE > Samsung Spinpoint F3 1TB
Q9. This seems the most popular choice at the moment. Other recommendations welcome
DVD/CD RW > ????
Q10. I understand there are a few problems fitting optical drives into a FT02B which would be my best option?
Final bonus question. what else will I need (extra tools, cables. fans etc) as I have never built my own pc before and want this to go as smoothly as possible
Any advice is welcome at this time as I'm inches away from ordering, any links you think might help please also mention and thanks in advance for reading my thread
CPU > I7 950
GPU > ????
DVD/CD RW > ????
