- 10 Sep 2009
Core i5 Build - £951
Core i7 Build - £1045
£94 difference between an i5 Build and an i7 Build. The Core i7 build has a better motherboard, I think, and i7 is more powerful. So, really, for an extra £94(!) it must be worth going for i7 instead? You also get 6GB of RAM compared to 4GB with the i7 build.
Unless I've done something wrong...
), im with you with not crossfiring so it seems i5 is all that would be needed for now, and if your currently not using more than 4gb then i suppose you gotta ask yourself if 6gb will benefit you at all, im also thinkin lga1366 will stay the expensive socket for a while where as im hoping more lga1156 will be a socket where affordable upgrades are possible for a year or so
