My new I7 build is nearing completion and the first test of my Coolit Freezone Elite looks quite positive.
Only real problem was mounting the Elite's I7 fitting kit due to the metal plate on the rear side of the mobo, under the socket (maybe i have not got that right as i had to double the plates up?, perhaps someone could enlighten me on proper fitment as the instructions specified the plate i have used but were not really that clear.)
Other than that, the next step is to see what the cooler is really capable of-i will keep you posted
screen shot of the Coolit software at work-i should have actually let the cpu temp drop before i took it as obviously it lags behind coolant temp.
