i7 bundle or i5 bundle ?
6 Nov 2011
Hey guys, im looking to replace my really old "AMD Phenom x4 955 BE" and motherboard.
I've got my eye on one of the discounted bundles on overclockers.co.uk. I am unsure if i should go for the:
Gigabyte Z97X-Gaming 7 - Devils Canyon Core i7 4790K CPU & Motherboard Bundle **£43 Saving**
or the
Asus Z97-K - Devils Canyon Core i5 4690K Bundle **£14 Saving**
It will be used to play world of warcraft:warlords of dreanor most of the time.
I want to be able to play at ultra settings on a 1080p monitor.
my graphics card is ASUS GTX 670 DirectCU II 2gb
Will the i5 bundle have any problems playing at ultra settings with a constant high fps? or is it best to spend the extra on the i7 bundle.
all answers and guidance is appreciated
thanks.
The i5 bundle will be fine for gaming, especially WoW. WoW isnt that CPU intensive, for most games the GPU is the most important thing.
thanks for the reply. i think i will most likely go for the i5 then. is there any motherboards out there that anyone would suggest for the proccesor?. im looking to spend around £250-£260 including the cpu. or should i just go with one of the i5 bundles.
As others have mentioned most games won't benefit from the extra virtual cores of the i7.
Save your money and go the i5 route...
