Hi, I've just bought a second hand set of parts for my first stab at an i7 build - that is an i7 920 (C0), Asus P6T, 3GB Corsair Dominator DDR3 (3 x 1GB).
I'll use my existing Antec P180, 4890 and OCZ 600W (E8400/Tuniq/4GB DDR2 will go to my son's rig)
I hope to clock to 3.8 which seems feasible with the C0?
What cooler do you recommend? - Corsair H50-1 (I've never used water and fancy a dabble albeit a gentle start) or which air cooler would be a good alternative.
I'll start with the 3GB Dominator kit but suspect I'll want to move to 6GB - would I be best to buy another 3 GB or sell it and buy 3 x 2 GB. If so, which brand is best value and should I add cooling to the Ram? I guess that is partly down to the CPU cooling route too?
Thanks, Andy
Thanks, Andy
