Hi,
Just wondering what peoples opinions on this are. I have an i7 d0 on a udr3. Cooling with a Noctua D14 with the ULNAs (resistors - low noise mode) and a Raven RV02 which has good airflow, fans all on low. I used MX3 paste.
Temps are as follows after 30 minutes small FFTs:
4.0 (191x21) @ 1.248v -> 75/73/72/68
4.2 (200x21) @ 1.31v -> 85/84/80/78 (draws an extra 50w out of the wall, too!)
Do these temps seem reasonable given the set up I have or is it likely I could squeeze out a bit more performance with a reseat/reapplication of thermal paste? What do people think of MX3 vs AS5 as I have both lying around!
Couple of other things whilst I'm here:
- Does QPI/Vtt have much effect on temps? Testing 4.2 was quick and dirty and I just put QPI straight up to 1.335 - is it worth trying to get it lower, will that help temps?
- I am thinking that 4.2 clearly isn't viable at the moment as I guess IBT et al would show 90'c plus - no thanks. That said, what do people think of running 85'c on P95? Too hot or okay?
My idle temps are about 41/37/40/35. Given that the summer is coming I think that I need to shave at least 5'c load off at 4.2 for it to be a sustainable overclock, do you think that is possible or am I just asking too much on air?
Many thanks for any pointers
