i7 help
27 Mar 2009
Err, not sure which component is the problem so i figure i'll post it here.
I recently bought the *OVERCLOCKED* Intel Core i7 budle pack from oCUK, it came pre-overclocked which i figured would save me a lot of hassle later on. I hooked it all up and booted it np, the splash screen for the motherboard came up followed by a short list of options with the first one saying something like 'Last know good config'. The computer then shut down and rebooted but this time didn't send a signal to my monitor, but is definatly powering up the board and the fans although theres no beeps going with it.
It now does the same thing every boot, just sits there with no signal to my monitor so I can't work out what the problem is, any ideas?
Seems like a failed overclock, which if is, A CMOS reset may cure but the overclock will need setting up agian unless they have saved a profile in the BIOS.
Your best bet is to speak to Overclcokers, either by webnote or customer services forum.
