Hey guys. Wondered what you would make of this. Got my i7 cooled on water and am trying to get 3.2 Ghz with Hyperthreading... easy doors right? The batch no is 3839A (which I haven't heard any horror stories for). Anyway, with a VCore set in the Bios of 1.275V, CPU-Z reads the Vcore on idle as 1.24V (a loss of 0.35Volts) and under load it drops to 1.2 Volts... my first question I suppose is, is that a drop to indicate a problem with my PSU or CPU? I'm not sure what sort of droop people see on the i7 processors. Anyway, thought 1.2V should be ok for 3.2 Ghz, so I ran 4 instances of Orthos and set the programme affinity in task manager to spread the load across all cores. One of the orthos instances failed after 17 minutes... joy. Anyway, I upped the Vcore to 1.3 Volts in the bios, under load this dropped to 1.235 Volts which I thought must be fine for 3.2 GHz with HT enabled, again, apparently not, one of the instances of Orthos failed again after 47 minutes. So I turned HT off and the overclock was stable for 5 hours... ?!|?! what the hell
) is my hyperthreading bust or something? I don't really have much experience with this i7 and I'm not finding it too easy to overclock this thing, just wondering if you guys think firstly, if there is a PSU or CPU problem from the droop I'm getting between Bios VCore and the realtime Vcore reading and secondly, if you think the chip is broken, not being able to handle Hyperthreading? Anyway, thanks in advance for any help with this guys =D
It's just... an inconvenience that a stress test is saying somethings wrong if you get me ^^ I'll give some different QPI settings a go. My motherboard is a Gigabyte UD4P and I've put the QPI multi as low as it will go though and I'm not too sure what the uclk is...
