- 17 Jun 2012
I'm mulling over either the 4790T or 4790S, is there a massive performance difference between these two bearing in mind the decent TDP difference?
http://ark.intel.com/compare/80808,80809
The performance difference is just the clock speed difference. The S will be about 16% slower at base clocks.
From a back of the envelope calculation this S is probably running about 10% less voltage than a non-S, combined with the 16% drop in clock speed for a 30% drop in power. As others have said, nothing you couldn't do yourself with the K version, but the K version can go up as well as down should you need it.
If saving 20W is absolutely critical then the S makes sense, otherwise it's a bad idea IMO.
