I agree on some things but i tried ht on and off with bf3, no difference really, server lag in europe is annoying but expected and origin and battlelog is probably the only things i would turn off but i doubt that is possible without some issues, origin is next to a trojan horse i heard from those with security awareness. Yep, so i leave ht onHyperthreading in BF3 creates a lot of problems and needs to be turned off too.
3930K vs 2500K
£499.99 vs £163.99
Discuss!![]()
Hyperthreading doesnt do anything for games, and also in BF3 it creates a lot of problems and needs to be turned off too.
hence why i don't trust review sites.This is why I shouldnt listen to what I read in reviews![]()
i have no issues with HT on in BF 3
Nope, there isnt any benefit.
what???Just because one doesn't, doesn't mean the rest don't either.
I bet there's still a few Xbox 360 launch consoles working, doesn't mean there wasn't stability issues.
The only reason hyperthreading doesn't do anything for games, is that most games don't make use of 5+ threads, and those that do would likely be GPU bound.
If you CPU bound yourself by turning your CPU to 1 core, 1 thread, recorded FPS, then did the same at 1 core, 2 threads, you'd notice a difference.
what???
reviews say with HT on you'll see stuttering. im just stating it doesn't
i didn't even say anything about if games benefits from HT or not
i think bhavv thought it affects all systems with HT onBut, point bolded, just because you don't see stuttering doesn't mean it didn't affect the reviewers, or hasn't affected other people.
EDIT : I'm sure on this forum I've seen posts of the stuttering, and disabling HT fixing it.
This has been written in lots of places. By reviews, I mean any user review or comments on the game too, and there have been lots of complaints about BF3 having problems with hyperthreading enabled.
also it doesn't mean it a 100% sure it will affect OP if he gets a chip with HT
if thats the case surely it would affect every system with ht onCould be a..... BD Buzzword incoming ; Thread Scheduling problem.
Since BF3's supposed to be able to use X amount of threads, it might be using the HT thread as the second thread, instead of a core, and keep on going, so some of the more strenuous tasks are done on the "weaker" thread.
Not the best phrased post, but you get the gist.
All it will do is make your CPU run around 10 degrees hotter, thats the only noticable difference you would see in a pure gaming rig.
The 2500k is the best CPU you can get right now for gaming.
