Ive got the rig in sig bar the psu currently got a 1kw ocz
running at 195*20
vcore is 1.276
ram is at 1.62
qpi volts are @ 1.3v
cant remeber the rest off the top of my head
the problem ive got is as soon as i up the overclock it crashes its a gpu crash system slows loads and then the screen goes a nice random colour and i have to force reset. It does this on boot at the moment too and i cant work out why any tips?
By the way it was stable at 195*21 before i put the second 5870 in there.
i cant seem to get past 195 stable either so hopefully i can fix both problems togeather
running at 195*20
vcore is 1.276
ram is at 1.62
