I7 Overclock Help
31 Mar 2009
Stoke-on-trent
I'm looking to over clock my I7 a little - maybe just to 3GHz for now and could use some help.
How do i do it? :D
I've got an i7 920 and a Gigabyte GA-EX58-UD3R Intel X58 motherboard.
Cheers.
PS I've had a look around the site/sites and it's a bit confusing for me, so i though I'd start my own thread where i can ask questions etc.
How do i do it? :D
Cheers.
Go into the BIOS and set BCLK to 150. Bingo 3.0GHz
Faster clocks get a little more complicated as you have to start tweaking other settings, but that should be doable out of the box and pretty safe.
There should be a Gigabyte tool that will do some simple overclocks for you.
Also, just to be on the safe side, check on your BIOS, the CPU temperature when you boot it up, just for a minute, to be on the safe side.
