I was reading something earlier regarding qpi and ram voltages, and how they should be set. (quote below)
You must keep the difference between dram voltage and qpi voltage within 0.5v
Should this be the case at all times, im currently running a 920 DO on the following voltages at 3.6ghz, (HT and turbo enabled) bclk 173x21.
vcore, 1.18
pll, 1.8
qpi, 1.2125
dram, 1.64
Passed 10 runs of IBT on theese settings (maximum stress), do theese voltages look ok. Thanks for advice.
vcore, 1.18
pll, 1.8
qpi, 1.2125
dram, 1.64
