I've been having problems with my current build for a while. Having swapped out everything but the MB and CPU I suspected the MB was faulty. In preparing to RMA it a friend and myself dissembled everything at his place (more room to work at his). He noticed that one of the metal pads on the bottom of the CPU is misshapen and I noticed that another is a richer copper colour than the rest. I can see where the pins had sat without problem on these pads despite the odd shape of one.
I haven't OC'd besides what the P6T does on it's own. I can't figure out if it's something I've done as I've only reseated it once and didn't notice them either time. I could have missed them easily as even knowing where to look I loose sight of these two pads amongst the others. Does anyone have any idea what might have happened or know if this is likely to cause problems?
I'd take a photo but I haven't a camera that will do the job.
Also does anyone know the correct term for these pads? Wiki didn't help much and just explained what they are made of.
Cheers.
Cheers.
