- 8 Oct 2009
Hi,
I need (well technically my friend) your professional expertise
My friend wants to build a PC which will be used for work (programming), Photoshop and design work.
So tools like Adobe CS and AutoCad will be used.
He wants to PC to last a good 5 years at least, and maybe overclock when he sees it's getting a bit on!
CPU - Intel Core i7 4770k Haswell
Mobo - Asus Z87-Plus
RAM - 16GB (2x8GB) Corsair Vengeance Pro 1866MHz
SSD - Samsung 840 Pro 256GB
HDD - 2TB Western Digital Green 3.5" 7200rpm
PSU - Corsair RM 850W
GFX - later on (in a month or 2)
OS - Windows 7 Professional 64-bit OEM
Some notes:
Regarding PSU - Not sure if 850W is a lot or 750W is enough, keeping in mind that something like a NVIDIA GTX 780 will be added later on.
Could you tell me if the components are good together or if anything needs to be changed?
Thanks
Some notes:
- RAM - He wants Corsair
- Power Supply - Corsair, Seasonic or Be Quiet
Thanks
