- 16 Nov 2006
- London
I have just built my first i7 machine using Gigabyte ex58 extreme, i7 920 D0, Noctua NH-N12P HSF (with 2 fans) and corsair dominator memory.
When checking the temps i get a pretty good temp for stock and stock running prime but as i start to increase the frequency (blck) the temperature goes up exponetially. I can only take it to 3.1ghz before it gets very hot. At 3.2 it is getting close to 100c.
Can anyone suggest anything i can do to clock it safely or am i just stuck with a less that perfect overclocking chip
Thanks for any suggestions.
(I have reseated the HSF several times)
Stock idle
Core 1: 37c
Core 2: 33c
Core 3: 36c
Core 4: 33c
Stock prime
Core 1: 54c
Core 2: 50c
Core 3: 52c
Core 4: 50c
3.1ghz @ 155 idle
Core 1: 56c
Core 2: 52c
Core 3: 54c
Core 4: 51c
3.1ghz @ 155 prime
Core 1: 82c
Core 2: 78c
Core 3: 79c
Core 4: 76c
Stock idle
Core 1: 37c
Core 2: 33c
Core 3: 36c
Core 4: 33c
Stock prime
Core 1: 54c
Core 2: 50c
Core 3: 52c
Core 4: 50c
3.1ghz @ 155 idle
Core 1: 56c
Core 2: 52c
Core 3: 54c
Core 4: 51c
3.1ghz @ 155 prime
Core 1: 82c
Core 2: 78c
Core 3: 79c
Core 4: 76c
