right i did post in the OC section but that was more oc stuff. so here we go.
these are the parts i already have:
Antec 900 case
ocuk GTX 275 (non oc atm but that will change soon enough xP )
Thermaltake toughpower 700w (non modular)
thermalright ultra extreme 120 +1xfan (775/am2)
soundblaster audigy 2
dvd rw
2x 320GB WD HDD (one cavier and one blue)
right think thats the important stuff i have (got mon, keyboard mouse etc etc blah blah blah)
and heres my preposed purchase:
thoguht may aswell get the retail version as its cheaper this week, i have heard good things about the asus board and like to stike with them as used them in the past and know what's what
gunna get that 1366 bracket for my old TRUE cooler so i dont have to spend another 50 or so quid on a new cooler (any idea when these will be in stock or should i just get them off a certain bay?)
also im sure ocuk used to sell the extra fan clips for the TRUE cooler but cant find them now.... will the ones they have on the site for a different cooler work or shall i search the bay amongst the e weed xP so yea i forgot to put the extra fan on there but thats fine.
would that memory be a good choice, i want to try and heavily overclock so gunna need some ram that can good high speeds was thinking this as it will give me some head way, and so if i dont reach that speed i can try to tighten the timings.
any better suggestions for ram? and how high are these sticks as my mate is going to give me a dominator cooler (the new 2xfan style for triple channel) and i need to know if they will fit under.... or if you can suggest much better ram then im all ears
im quite leaning towards the 1600 dominator ram now actually ^^
EDIT: almost forgot, my 700w PSU.... this should be more than enough to run this spec with overclocks yea? *crosses fingers*
Antec 900 case
dvd rw
gunna get that 1366 bracket for my old TRUE cooler so i dont have to spend another 50 or so quid on a new cooler (any idea when these will be in stock or should i just get them off a certain bay?) also im sure ocuk used to sell the extra fan clips for the TRUE cooler but cant find them now.... will the ones they have on the site for a different cooler work or shall i search the bay amongst the e weed xP so yea i forgot to put the extra fan on there but thats fine.
not happy with that! apparently they are getting a delivery tomorrow morning and so my package should still arrive tomorrow.... but i have a feeling that's hot air and i wont get it till monday now...
