i7 Watercooling advice....
Permabanned
21 Apr 2008
Gloucester, UK
Ok, I want to watercool my set up (CPU & GPU)
Can you advise some parts for me - tubing size, strength of pump, compression fittings or not, etc.
Also, I have been told that I can't fit a triple rad on a Antec 1200 - is this right? And if so, would a 120.2/240 rad do the job?
cheers
a 10w laing would do a cpu/1card loop tbh
With far fewer issues when it comes to bleeding the loop. The 18W is OTT for most projects, and it's often very noisy because it's whooshing away and the air never gets a chance to bleed out.
Uh oh, now you tell me. I just ordered an 18w. Mind you, I have an Ehiem 1200 at the minute, do you think it will be quieter than that?
