i9 9900k + z390 Aorus Master 4.9ghz?
So i've been trying to overclock my 9900k to 4.9ghz all cores but can't get it stable.
I can get through cinebench with AVX offset at 1, but system crashes out after a few minutes on prime98 with WHEA UNCORRECTABLE ERROR.
Running latest F11c bios version.
I also have this weird behavior that I have to enable Turbo Boost, then set all Active Turbo Ratios to 49 or whatever else then disable turbo boost, otherwise it will run the previous ratios if I just disable turbo boost.
Config:
i9 9900k
Trident Z Neo 3600mhz 2x16
NZXT Kraken x72
Gigabyte Aorus Master
Heres all the settings I've changed.
Config:
i9 9900k
NZXT Kraken x72
