Hi all,
I have just done a first time overclock on my new rig. I have used the Asus Rog AI utility followed by tweaking with the Asus Intel Extreme utility.
My old idle temps were :
https://www.screencast.com/t/EFDBP8YAy
My new ones are :
CPU-Z shows :
https://www.screencast.com/t/lFyy3AhJ
Does that seem OK or should I back things off ?
My system spec is :
CPU: Intel i9 9900k
MB: Asus ROG Strix z390-F Gaming
Ram: Corsair Vengeance RGB DDR4 3000 MHz RAM - 32Gb (2x16)
GPU: MSI RTX 2080Ti Trio Gaming X
Cooler: Corsair H100i Pro Pro RGB AIO Water
M.2 SSD : Seagate 2tb Firecuda 510 M.2 NVME (boot O/S drive)
SSD 2 : Samsung 850 Evo 1tb
HDD : WD Black 3TbPSU: Corsair HX1000 Fully Modular
CASE: Corsair 780t WhiteFans : 3 x 140mm Corsair LED AF - 2 in front (intake), 1 in rear (exhaust) plus 2 x 120mm RGB Corsair on WC Radiator
OS: Win 10 Pro
Keyboard: Logitech G910 Orion Spark, Mouse : Logitech MX Master 3, Monitors : BenQ 27" 1440, Headphones : Razer Nuri Ultimate
My new ones are :
CPU-Z shows :
My system spec is :
CPU: Intel i9 9900k
OS: Win 10 Pro
I think maybe the case helps as well - It's a Corsair 780t with two 140mm fans pulling on the front and one 140mm pushing at the back. The rad is mounted horizontally on the top of the case with 2 fans on it.
