iAudio XL5 or Creative Zen Vision:M
Don
23 Oct 2005
North Yorkshire
I'd like opinions from owners of the above please.
Currently looking for an MP3 player for my holidays, I have about 18GB of music so the storage of both players are more than capable at 30Gb.
So far I have learnt:
XL5, is more for the "bass" boys, I listen to metal music, so bass is quite important to me. Apparently the Creative doesn not have EQ settings?
Comes with remote control (also important to me)
The Creative I have learnt doesn't come with either a AC adaptor nor a remote which I would both need, I know both can be bought separetly.
Has superb video playback and more supportived formats than the above.
Both are similar price, the XL5 being a bit more, however, having the remote and AC adaptor alone attracts me to it.
So can anyone shed some light on the above? What is your verdict on the players?
I am definately more bothered with the sound quality than looks.
Thanks
I've just got the Vision:M and am blown away with it, especially the video capabilities, which are much better than I could have hoped, superb!!!
It does come with an AC adapter as well mate and you can get the remote from eBay for under a tenner, which I did the other day.
andybtsn said:
Yeah I checked the other post when you got yours mate.
What's the sound capabilities? Can you adjust bass, treble etc? There's no EQ settings where you can choose Rock, Dance, etc etc?
There are various EQ settings, for Dance, Rock, Jazz, Disco etc and a Custom EQ for you to use, easy to do in the System folder. ;)
Soundwise they are both pretty similar. The big difference is that the X5 is a UMS (doesn't need drivers - appears as a USB drive) and can use filetreee. The Zen needs software installed to get music across to it. Also the Zen uses a touch control slider (which I don't like) the X5 uses a joystick. The X5L is a version of the X5 with longer battery life. The X5's are very poor at video playback. Do a search on the portable section over on Head-Fi.org for more info.
Ooooh, thats looks nice!
I will wait for your opinion, could you add em to your MSN? (msn in trust) I need to order one pretty quickly.
james.miller said:
Products
1 x i-STATION i2 30GB Media Player I2-30GB £239.00
1 x PMP1000/i2 5400mAh Super Battery ACCI2BATT5400 - Colour: BLACK £24.99
What the battery for?
added
the standard batter is a 2700mAh part. I ordered the 5700mAh battery to go with it, increasing battery life substancially:)
james.miller said:
i was looking at the same two players - the x5l 20/30gb and the vison:m.
in the end, i choose the istation i2. ive not got it yet (wil have tomorrow) but form the specs alone it runs circles round those two. hold of for a few days and i should have some sort of review up:)
http://forums.overclockers.co.uk/showthread.php?t=17591117
Jeez, I wish I'd seen that before I got the Zen, although I love it and it's faultless video playback, that does look awesome.
I'll look around for some reviews, including yours obviously and I might be tempted to sell the Zen and go for that, although it's a fair bit bigger and heavier than the Zen. :)
Zen Vision M Does not need its own software! All you need is Windows Media Player 10 or 11 and then the Zen is drag and drop!
The Zen does have bass but not as much as the x5l with mach3bass.
To give an idea how the Zen sounds.... It sounds the same as if I plug my headphones into a hifi like a NAD setup - very big full sound!
Has anyone seen the Toshiba Gigabeat S MES30VW for sale in the UK?
It's actually the highest rated MP3 player on cnet.com, uses the Windows Media platform, looks very good.
But can't find it anywhere in the UK
pretty sure the gigabeat s series won't be coming to europe, usa and asia only from what i've read.
