- 1 Jul 2019
Hello All
I have 6 x IBC tanks each holding 660 Litres, connected together using 2” / 50mm pipes. All tanks are vented.
I’d like to use them to mavity feed my cold water toilets cisterns x3, kitchen sinks x2. Tanks are up in the loft 2 meters above where the water needs to go. If I used a 3/4” 22mm water pipe to feed all mentioned, will I have enough water pressure? Or will I need a pump?
This is an off grid house I’m building
Many thanks
Many thanks
