IBM AS200 i series
12 Jan 2009
Hi all,
I need to learn about the IBM AS400 servers but I can't find any tutorials or guides online. Any ideas guys?
EDIT: Title should read AS400 not 200
AS/400 / iSeries isn't the most widely used kit out there for guides will be fairly scarce. Is it hardware or software info you're after?
The IBM infocenters are here
Run into this problem myself quite a bit. We have an AS400 server at a site I manage the IT for, it runs an old ERP system they still use but we have medium term plans to replace it depending on how rollout goes at other sites. We have hardware support for the servers luckily but don't have support for the software any longer.
Only problems i've had in the past couple of years have been overheating and network connection dropping out. The printers cause me no end of problems though and the resellers charge a fortune for replacements (which still cost less than it would for a call out and repair).
Have never been able to find anything coherent online like tutorials or the like. Even though they are dead end systems there is still quite a market for support, maintenance etc, and even though our support contract isnt with IBM it is their engineers that come out for problems so its probably in their best interests to keep information scarce.
Blimmy !!!!! I have worked on AS/400 since it's launch - late 80s :D
RPG programmers are a dying breed of dinosaurs :p
to be honest, if your company is using them, then they should be able to afford to send you on a specialised course.. Not the sort of thing young can pick up from "dummy guides".
www.code400.com some useful resources in here
Onn the contrary, these robust pieces of kit are stillvery much used by most banks due to their reliability and ability to crunch large numbers. Our down time hours for iSeries over the last 5 years = 0.
