IBM BladeCentre SSD specs?
27 Nov 2008
Ayia Napa
As per title. I just bought one accidentally on purpose (32gb) but have no idea of the specs. Apparently they're intel and support TRIM but that's as much info as I can find.
Any ideas gents?
IBM 50GB SATA 2.5 SLIM SSD
SATA SOLID STATE DRIVE
This is not a stocked item, general lead time is 13 Days
PI DATE : Apr 2009
PRODUCT : IBM 50 GB SATA 2.5 SFF Slim-HS High IOPS SSD
DEVICE TYPE : Solid state drive
FORMATTED CAPACITY : 50 GB (Up to 50, 000 MB)
INTERFACE : SATA
FORM FACTOR : 2.5-inch SFF Slim
PERFORMANCE CHARACTERISTICS:-
DRIVE TO HOST INTERFACE That supports 1.5 Gb/s burst rate
INTERNAL TRANSFER READ RATE : Up to 80 MB/s
INTERNAL TRANSFER WRITE RATE : Up to 50 MB/s
IOPS : Combination 67% Read/33% Write transaction processing
rate: up to 2600 IOPS
COMPATIBLE DISK BAY : 1 x 2.5-inch Small Form Factor (SFF) Hot-swap-Slim
* SATA SSD drives are supported with major operating systems,
including Microsoft Windows and Linux
* Up to 50 GB capacity for the single drive delivers high-performance
Input/Output Operations per Second (IOPS), thereby relieving
storage IO bottlenecks
* Investment protection and ease of use
* The absence of moving parts reduces potential failure points
in the users server
* S.M.A.R.T Technology allows software utilities to alert users of
certain impending drive failures so replacements can be made
before a problem occurs
* NOTE: User capacity may vary depending on operating environments
I gave up on the IBM support pages, but the specs are there somewhere. Ripped the above out of an online retailer somewhere in Australia :P 32GB and 50GB are identical, as far as I can tell, except for capacity. Hope this helps. Does not look too great on its own, unless you RAID it. It scales quite well in speed oriented arrays, apparently.
Thanks very much for that, I was lost in a sea of IBM store listings with no sign of an answer. It was £30 so I'm not too fussed about speeds, it's for my Dad's work PC where silence is much appreciated.
Thanks again :)
