- 22 Aug 2005
- Clydebank
Hi all
Anyone still running one of these?
I'm interested in a portable (i.e. 12 inch) laptop and there are some PCs around this spec, I can't feel happy about spending 150-200 on 64M PIIs so I see one can get Ibook G4 for around 200 quid depending on spec and this looks like a winner to me... because the smallest new mac laptop you can get is 13 inch at 700 squid - too expensive.
And they run OS X
Can these run Leopard 10.5?
What is the minimum recommended RAM amount I see them with 640 / 768 / 1.5 GB (like, win xp will run in 128 but 256 is a good min, and it requires 512 at least to be useful and 1GB is plenty)
Do they all come with WIFI as standard? I have a WRTGL router.
Any one know of common probs and easy fixes (i've seen a few with no backlight, for example)
How good os the sleep/suspend/resume functionality?
And...
What would be the minimum spec you would feel happy using on one?
EDIT oh and do these take standard laptop memory so I could in theory get a lower spec and upgrade with more ram?
Regards all..
And they run OS X
And...
Regards all..
