iBook G4 ram help
16 Dec 2007
Hi
I’m trying to fix an iBook G4 for a friend. It keep freezing and very rarely makes it to the desktop. I’m almost sure that it’s the built in ram that’s the problem.
I can’t get into the system long enough to run mem test and i cant boot from CD, it always freezes. I ran FSCK which came back ok.
I want to know if its possible to disable the built in ram and only use the second ram expansion under the keyboard.
FSCK - File System Consistency Check. Basically the *nix version of chkdsk.
Will attempt to fix invalid files on the disk.
Won't resurrect a drive with hardware faults.
Pretty much redundant on modern macs as they use a Journalled filing system that can heal itself.
