IBT gives lower temp than Orthos
5 Aug 2006
Kent, UK
I usuually use Orthos (blend test) to test stability. I've run it for 30+ hrs so i'm pretty sure my OC is stable. Thought i also run IBT to test it again and see what the max temp for the cpu at this OC is.
Win 7 64, running IBT 64 bit mode, stress level max, threads auto, runs 10. The pc passed but strangely the highest temp it reached was 55, where as with Orthos it'll hit 60.
Measuring temps with speedfan.
I'm i doing something wrong with IBT? everyone else seems to get higher temps from IBT than orthos.
