IC Diamond 24 - long term stability
19 Nov 2007
Leicester, UK
Almost 2 years ago I was sent some ICD 24 to test in the big give away.
The results back then were
Load test 1 hour prime small fft's
Ambient....20.9
Water.......24.6
CPU..........49-44-47-45
And today 1 year 9 months later, same system, same over clock, same water cooling, even the same water.
Ambient....21.4
Water.......24.9
CPU..........49-45-47-46
Pretty much identical results. Looks like its stands the test of time. (so far)
Some thing I cant say for other pastes I've used, where after 9 months or so need to be changed to get the temps back down.
Just a thumbs up for the longevity of performance of ICD 24.
I found no change in performance as well. I had it on my CPU for 12 months and recently changed over to a H80 and put a fresh layer on (from the original tube).
