- 31 Oct 2012
- Edinburgh
Note, the 5.5mm example relates to a 30mm X 30mm square size. For larger or smaller square sizes you would ratio the amount i.e. 15mm X15mm = 2.75mm 1/2 pea size
For a quarter the area you use half as much? Why not 1/4 pea?
Edit: Is the 2.75mm meant to be the diameter of the blob? So halving the size of you 'pea' in two axis to end up with 1/4 of a pea in volume? Though I'd imagine it'd end up being smaller in the 3rd dimension too, so would end up even less... hmm.
