IC Diamond
7 Jan 2009
Gonna need some new thermal paste re-applying to my i7 860,And came across two diffrent IC Diamond,s.
Question is....Is the 24-Carat tube any better than the 7-Carat tube? are there any performance tests between the 2?
Ive never heard of this brand before.
24-Carat
http://www.overclockers.co.uk/showproduct.php?prodid=TH-001-ID&groupid=701&catid=57&subcat=27
7-Carat
http://www.overclockers.co.uk/showproduct.php?prodid=TH-000-ID&groupid=701&catid=57&subcat=27
The 24 is more expensive obviusly,But its a bigger tube...But then again by the time i will use it again it will have probably dried up! and thats why i was thinking just go for the 7 carat one as its a smaller tube and cheaper!
What you think chaps?
I'm not sure. I just bought some today (the smaller tube) i didnt realise they were different types i just assumed the other one was more expensive because of the size.
God dammit.
I've used both and didn't notice any difference between the two. Temps are good even on a heavily clocked Q9550, cooler at load than AS5 that I previously used idle wasnt really any different.
