Hello all,
I've always been able to click on ICA files on webpages and the Citrix connection fires up fine.
I've just received a new machine and install ICA client 9.1, and FF 1.5.0.1. I've ensured the plugin is installed (even though I got the same problem when the plugin wasn't installed), and I've tried all the options (use plugin, use default application, use "this" application).
The only thing that does happen when I click on ICA links is that it loads the ICA file into a new tab in FF as a text document.
Has anyone come up against this, or can someone re-produce it. I've tried to uninstall FF and re-install it (clearing everything off the machine).
Geoff
Geoff
