iCal import
4 Jan 2005
I am getting prepared for the arrival of my macbook fairly soon and would like to transfer my calender information from outlook 07 to the new macbook, can I just export the info from outlook and then import to iCal, i presume this works, what sort of file types does iCal support for imports?
To migrate your events and information from Outlook Calendar to iCal, just follow these steps:
Open Outlook and go to "File" > "Import and Export" > "Export to a file."
Select "Comma Separated Values (Windows)."
Select the calendar you want to export, save it to your desired location, then click "Finished." (Note: When exporting more than one year's worth of data, we recommend that you divide your calendar into multiple, one-year segments and export each file separately; otherwise, you may encounter errors.)
Select the desired date range of events to export, then click "OK."
Open iCal and just "Import" the data :)
(** Only formats and filenames that end in .ics or vCal formats filenames that end in .vcs will work **)
