Well, they'll just charge you the difference which is £10 or £15
Then I'd use 2 channels to power the front speakers (100rms x 2) and bridge the remaining the power the amp (~280 rms). If the car has rear speakers, you can run the rears from the HU. All that should be very loud. Also, you have one pre out left. So in the future, I recommend using the amp to run 4 speakers and get a meaty mono block amp (500-1000rms) to power a nice sub.
