- 30 Dec 2002
Now I finally have a car worth spending some money on I think it’s time I bought some decent ICE and a satnav system, however after having browsing a few online shops and reading some threads on here I’m thoroughly confused, so I thought I’d ask you folks for some advise.
At the moment I currently have a Sony F7750 installed which looks something like this (but much worse in real life):
However I don’t like it at all, as it doesn’t match the car what so ever and sounds worse than the factory fitted stereo. Sometime this afternoon I will be fitting the factory stereo back into the car, but, while it looks and sounds much nicer, the CD changer sometimes skips, which is a tad annoying. As my car is the Exclusive model it comes with the premium 10 speaker setup and therefore I won’t be changing the speakers at any point in the near future, as I think they sound great (compared to my old car at least).
I also want to fit a decent satnav system in the car at some point, so I have thought up three possible options:
Thanks for your time.
- Replace the factory fitted CD changer and buy a separate satnav system, the main advantage here is that I can keep the factory stereo (which I think really suits the car) however I’m not sure if fitting a different CD changer is even possible, and it’ll be a bit of a pain wiring the satnav up to keep everything looking tidy.
- Buy a new head unit and a separate satnav system, this is probably the cheapest option but apart from that it’s my least favourite idea.
- Buy a combined head unit and satnav system, this is probably the tidiest way of doing things, but also the most expensive, also I’m not sure how good the built in satnav software would be compared to a stand alone unit.
