Hey there,
My cold cathode tubes was looking a bit tired, and the power box the two plugged into started making strange whistling sounds and noises which started to annoy me and iv always wanted some led lighting in my case.
So I purchased some cheap RGB led's off of the bay auction site.
I opted to go for the £12 kit (2m length), because my idea was to route the power cable from the wall socket into my case, but then I realised theres no holes big enough to fit the wire through... So I could have just gone for the cheap £6 kit, because I braved up and decided though I know nothing about electrics to hook it up to my PSU! so heres how it went:
Here is what the kit includes
This is what I cut in half to find the black and red wires
And I cut the black and red wires off of my old cold cathodes cabling,
But you do not need to do this, just cut the old Molex plug off of anything and connect the black and red's together and your good.
Here it is wired up, I just used insulation electrical tape because I don't have a solder or anything like that, but after all its electrical tape so I figured it will either work or go with a bang!
It worked!! my face lit up like a Christmas tree, I literally stood back from my pc and pressed the power button with a shoe incase it went bang because like I said, Im not very good with electrics! but if I can do this, then anyone can do it, it was a absolute piece of cake!!
The led strip comes with sticky back, so time to stick it around the case
As you can see 2m length is Perfect for the 750D.
Now I will leave you with a bunch of pictures of the colours, there is a lot more colours than pictures I took here, though sorry about my bad camera work, a phone
Overall im very pleased with it! I love how I can change the colour, brightness and everything, can even have it to change colour automatically really slowly or fast or flashing or anything, but for now I just leave it on a static colour, I think it looks much better, never again will I buy expensive lighting!
Hope you enjoyed reading
