Icloud Photo Library
19 Aug 2008
Bournemouth
Hi all, I just upgraded to the photos app and it started uploading the entire photo library online, for some reason it has just stopped at 10GB and isn't uploading any more??
Is anyone else having these problems? I realise the servers might be getting hammered at the moment but surely they should have the capacity?
Is there anyway to check for dupes in this app? I now have, for nearly every picture, 3 versions of each photo, a low res, mid res and high res version....doing my head in!
I noticed the same thing but I had already created a library on the public beta. I've ended up deleting my whole library and started manually weeding my Aperture library.
Gonna wait till everything is removed and disabled (30 days) and then start a fresh with a nice deduped Aperture library.
Ive had the opposite experience,then I realised it only uploads from the main library in Photos,I have a number of libraries within photos so i go into each one and set it as the default and then it seems to send to the cloud,but I'm not sure if this is the correct way to do it,but if you have multiple libraries I can't see another option.
any ideas?
thanks
