Hi i current have two pcs connected via crossover cable, i have ics enabled and it works fine apart from when i install a firewall.
I dont really feel safe with windows firewall.
Can any of you recommend a firewall which allows ics.
Ive already tried using zone alarm and outpost both dont work, or will work till a reboot then its all buggered again.
Thanks in Advance
Thanks in Advance
