chimaera said:What hardware have you got and how is it set up?
You can have a router coming off the cable modem that allows each device to connect independently, or you can have a crossover cable coming from your PC and going itno the xbox.
The disadvantage of using a crossover cable is that the PC will have to be turned on to transfer the signal.
Oh and make sure its a crossover cable too, not just a standard ethernet one, as that wont work.
Vicar said:I done this years ago when I networked two computers together. The only problem with this is, that you will need the 1st computer on to share the connection, which can be a pain tbh. I really think getting a reasonably cheap router would be a better option.
Vic
