IDE for PHP similar to Visual Studios?
12 Jun 2005
Hi there,
Looking for an IDE for PHP which is similar to Visual Studios in the respect that is does a "snap-to-grid" thing so the code looks nice and readable.
Is also alerts when when i haven't put the end of line delimeter or when some brackets are not closed.
Is there anything like this for PHP?
Currently using Notepad++
Thanks.
Nothing wrong with Notepad++ - i wrote my company's entire website in that, or any one of language sensitive text editors - vi/vim or gvim for windows for example
PHP Designer (my preference)
PHP Eclipse
Nvu
and there are many many more...
Do these deffo do what I asked?
Not saying there is anything wrong with notepad++. Ideally i would like to still use it, just with what i asked for.
NP++ does do what you asked for, i think, unless we have our wires crossed
Make sure you have tab characters on and have set the language to PHP, also bring up the function list - very useful for big files.
Sort of does it, not exactly what i was after though.
I have to use the "C++ re-indent code" menu button to get it how i want - i want it to do it automatically.
EDIT:
Also - is it possible to pad the actual text editing bit so the text starts padded to the right more.
I'm not sure, i think you can do auto-tabbing though, there are also tools which you can use to auto-layout code, but not while you're writing it.
another vote for zend studio here. although if its odd files i'm changing ill use 'e' or notepad++
It's not an IDE, but e will indent for you as you type. It also has macros to insert code templates, so typing:
Code:
if<tab>
becomes:
Code:
if ( condition ) {
} else {
...with tab cycling through each of the three insertion points. Which is even faster than auto-indenting :)
http://www.e-texteditor.com/
Just installed eclipse PDT (on Win XP) and got it working with Xdebug on an ubuntu 8.04LTS dev server and it works pretty well and it is free.
