Im looking to neaten up the interior of my case, and am sick of my cdrom ide cables.
So, can you get adaptors that turn an ide interface into a sata one?
Cyanide said:You can't change IDE into SATA, but you can use rounded IDE cables to neaten things up
fornowagain said:Yes you can. You can buy IDE adapters that plug in the back of the drive and let you use sata cables. Or plug in the IDE MB header and give you sata outputs. I've got one, never used it. Auction site may have them, no idea if they work on CD drives tbh. But hey.
The one's I was looking at are about £6squiffy said:They're about £16 a pop, too expensive really. Just buy new hard drives with SATA as you go along
Energize said:, you dont have to worry about the sata cables snapping the end of the drive off
most SATA cables stick out more than IDE and have a smaller footprint on the back of the box, so the force of being knocked is more damagingSteve-O 2006 said:how does that happen?
