Buy an el cheapo sata card? Probably work out the same price.
Yep just put the HD inside the caddy and connect the cables up inside to the back of it (i.e. power + sata leads). You then just plug in the usb cable from it to any PC or Laptop. It is an external enclosure so you can leave it sat on top of the PC plugged in, for example.How do these work, do you put your hdd in the caddie then connect the caddie to a USB port?
Does it fit into a of case, how do you power it?
