- 22 Jan 2010
Hello, not sure if this is the right place to put this. So I've ran into a situation. This is my current PC case. I really love it but it doesn't really agree with my new graphics card (EVGA classified 780) as the heat sink blasts the air out to the side and as you can see the case has no form of ventilation on the side panels.
Taking the side panel off gives me a massive 10c difference to the gpu underload and I really want to push the OC on this card so I was thinking about doing a basic mod to add some ventilation to that side panel but I need advice.
At first I was thinking about adding a fan or two to the side but I'm not sure if that would mess up the air flow as the fans on the GPU would be trying to suck air into the heat sink while the side panel fan would be trying to push air out of the case from the same area. So maybe simply having a grill in the same fashion as the one on the front would be a better idea.
What do you guys think?
