**IDEAL FOR PROFESSIONAL PHOTOGRAPHERS & COLOUR CRITICAL APPLICATIONS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is expanding in the colour critical market and our first addition is a colour critical monitor from Asus, we shall also be recieving the NEC colour critical range as well soon. But to get the ball rolling this monitor from Asus is an absolute bargain price wise and includes hood and colour calibrator:-
Asus PA248QJ 24.1" Professional ProArt Widescreen IPS LED Monitor - Black /w hood and calibrator @ £419.99 inc VAT
Experience professional-grade colour fidelity and reproduction with the ASUS PA248QJ ProArt series LCD display. Each PA248QJ guarantees industry-leading colour accuracy, having been pre-calibrated to minimize the colour different to ?E < 5 right out of box. The PA248QJ delivers 100% sRGB colour reproduction on its 16:10, 1920 x 1200 optimal HD A+ IPS panel with 178° ultra-wide viewing angle.
PA248QJ also provides the best colour calibration solution of a monitor hood and Spyder4™EXPRESS calibrator to achieve the colour precision, accuracy, and consistency. It is the world's first monitor with four USB 3.0 ports, ensuring enhanced productivity thanks to data transfer speeds that are up to 10X faster than Current USB 2.0 standards. The out-of-box settings are impressive as each PA248QJ is pre-calibrated at factory to prove the best colour accuracy. To ensure that each PA248QJ produces the most accurate and consistent colour, we carefully measure its ?E and gamma value and track its gray-scaling. It even supports both Gamma 2.2 for PC and Gamma 1.8 for Mac - offering users more flexibility to work with.
Each PA248QJ guarantees industry-leading colour accuracy, having been calibrated to minimize colour difference to ?E (Delta E) of less than 5 - ensuring precise reading of colour input and guarantees excellent colour fidelity. Displays change over time and recalibration would be needed to return it to reference state for brightness and colours. With bundled Spyder4™EXPRESS, including a colour colourimeter and software, so that the photographers and designers can work confidently on PA248QJ calibrated monitor and assert greater control over the colour fidelity of their digital process. Moreover, PA248QJ also provides an accessorized monitor hood to help reduce light reflection and glare from ambient lighting for optimized screen performance, enhanced colour calibration and quality image making
Features:-
- Professional-grade colour fidelity with pre-calibrated ?E <5 for industry-leading colour accuracy
- True, precise colours on a 100% sRGB, 16:10 aspect ratio, 1920 x 1200 optimal A+ IPS panel
- The world's first monitor with four USB 3.0 ports for 10X faster transfer
- ASUS-exclusive innovations like QuickFit, Splendid™ and 5-Way navigation key for enhanced productivity
- A comfortable viewing experience with award-winning ergonomic design with tilt, swivel, pivot and height adjustments
- Work confidently and precisely with the bundled ASUS colour calibration solution of a monitor hood and Spyder4™EXPRESS calibrator
Specification:-
- Panel Size: Wide Screen 24.1"(61.13cm) 16:10
- Panel Type : IPS
- True Resolution : 1920x1200
- Pixel Pitch : 0.270mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 80000000:1
- Viewing Angle (CR?10) : 178°(H)/178°(V)
- Response Time : 6ms (Gray to Gray)
- Display Colors : 16.7M
- Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Color Temperature Selection : 4 Modes
- Color Accuracy : ?E? 5
- Gamma adjustment : Yes (Support Gamma 2.2/1.8 )
- Color Adjustment : 6-axis adjustment(R,G,B,C,M,Y)
- QuickFit (modes) : Yes ( Modes)
- Picture-in-Picture
- Picture-by-Picture
- HDCP support
- Signal Input : HDMI , D-Sub, DisplayPort, DVI-D
- Audio Output : HDMI
- Earphone jack : 3.5mm Mini-Jack
- USB Port(s) : 1 x upstream, 4 x downstream
- Warranty: 3yr
Only £419.99 inc VAT.
ORDER NOW
